BR 193 400 pulling a CD Eurocity on my era VI Layout
Some pictures of my br 193 400 which is quickly becoming one of my favorite locomotives in my collection
PixelLok, casey-jones and 6 others2 Comments- View more comments
Want more TRAINS!!!!
Another project I’ve been working on. This is a stone arch bridge carved from a scrap piece of foam. Next step is a light coat of paint and some various other washes/finishes.
If only
Unoki
Almost finished
Got the ballasting done on my 2ft by 4ft diorama. I learned some new tricks to make the ballast look better than on past layouts. These include using 91% isopropyl alcohol and using a pipette for applying the glue.
I found that if you apply the glue using the pipette on your ties you get the cleanest look. The glue washes the tie clean of…
Little more work completed on the canal. I added some highlights to the rock faces. I also added some olive paint around the rocks in the canal itself. Still need to add more between the rocks to show water flow areas. Hopefully when water is poured, this will show a good transition between the shallow and deeper spots.
BLI Paragon 4 SD40: Is it any good?
Recently, I bought an HO Broadway Limited Imports Paragon 4 with DCC and Sound, in Conrail livery. (Shown below) Some say that it has outdated tooling… but does that matter?
I purchased the model from Yankee Dabbler. It was shipped in a standard shipping box with barely any cushioning between it’s own box and the shipping box, allowing it to…
