Proceeded with ballasting the track
EF65 + ShiKi 800
EF65 + ShiKi 800
Electrical Work - My Controller
For this layout, I needed independent control of 3 separate blocks—The 2 mainlines, and the yard. I couldn’t find any commercially available 3-way controllers on the market, so I decided to build one, as opposed to buying3 different controllers, which would ultimately have cost more (although make no mistake: This was not rock-bottom cheap).…
Electrical Work—My Control Station
In my previous post, I briefly mentioned how I will be using PC connectors as quick disconnects so i can easily detach my control station from the layout.
To build on that, I figured I’d make a post regarding the control station itself.
I started with a roughly 2 x 2 1/2 foot piece of 5-ply plywood i had laying around. I then drilled two holes in…
This is how my layout is now!
Electrical Work - Running the Mainline Buses
The last day of 2025, I finally got around to starting the wiring on the layout. On December 31st, I ran the the buses for the double mainlines. Each bus consists of 2 16AWG wires—1 red, 1 black. They run through little holes drilled in the 1x4s on the underside of the table. I also connected the first PC connector that will be used as…
One part of the layout from my grandfather who inspired me!
Actually very nice scenery when you think that there where almost no scenery brands with nice products to build some great scenery!
Track Work - Completing the Mainlines + The Temporary Extension
Once all the switches were installed, I was able to finish permanent work on the mainlines, which consisted of only a few sections on the northern end of the yard. But that wasn’t enough. I wanted to run trains continuously, which wasn’t possible since I’m only building one half of the layout at the moment. That is, until I set up a…
0:35
